I actually put a little bit of Lucas Power Steering stop leak into the ACE reservoir, it has pretty much stopped leaking. ACE still works fine, so all good to go for now.
I never did find any info on the metal line to the valve block, so in the event my ACE blows a line it'll be converted to a normal setup from my parts truck. |
Old thread I know - but I'm replacing my line and have part numbers:
ACE Pipe High Pressure Pump To Block *Front Section Of Front Pipe* V8 (Britpart) RQB000270 ACE Pipe High Pressure Pump To Block *Rear Section Of Front Pipe* (Britpart) RQB000380 Collet Clip Pipe Ace|Part Number:ANR6700 ACE Pipe Seal (Valve Block End) OEM RVW100010 *One Per Pipe* |
