ACE Pics
ACE Pics
Ok Gentlemen I need some help.
i have a 2004 G4 that i am adding ACE to and the pic folder of all my mounting and Gyro mounting git corrupt somehow and I do not have any.
ANY of you 99-02 Guys have any pics of you ACE system you can share. it would be HUGE help
My lines are already in just need help with all the mounting and what gets the rubber isolators and the other that are bulted together.
Then the Gyros rhat are mounted on the freme and in front of front sunroof motor need how they are mounted so I can rivet in correctly.
Thanks SO MUCH Guys. This project has been ongoing for 3 years and I am getting into it to get it wrapped up and at paint by June1.
Color me jealous as ACE is one thing I wish both my ‘04s had. Quite an undertaking, though, to get it added in. Are you doing frame off or trying to do this with everything in there? Impressive if the latter.
As for pics, which locations? I had ACE in my ‘00 and love the system dearly, but wanted to give the 4.6L a try. Both together would be heaven.
This is a pic from the system, but assuming you have the RAVE, there are a slew of good pics in there and a total description of the function.
Personally I think it’s worth it as I’ve driven a few Discos- lifted and not- with the system, and I’m a huge believer. But as I’m not planning a multi year resto on either of mine, I’ll muddle through having a bit of wallow in my handling and significantly less suspension articulation.
Charmin
Charmin,
Just like sally said. TIME TIME TIME and TIME IS MONEY. You will need a 1999-2002 COMPLETE donor vehicle. its best to have the ACE in operational state before you pull it. That way no surprises when you start up.
I took all the hardware and all 3 entire harnesses off of donor vehicle. Including all Computers. Then I ordered all new RAM units, Gimbles, Dampeners, Valve Block seals and collets. and service kit with filter
Yes, you can install without frame off it is easier than removing body.
If you wanted me to put a dollar figure to it.
I would charge around $7500-$9k labor, Parts would be about $1500 plus whatever the donor vehicle cost is
It is not difficult, it is just VERY TIME CONSUMING.
I should have it all finished and off to paint within the next few weeks, wife permiting.
I will post pics when I get it back
longtallsally (05-21-2024)
ACE Pipe to Pump - Need help
Can someone please help me? Nobody is responding to my post.
I have a 1-2cm split in the hose that connects to the pump. I tried to fix it with gasket sealant. Too much pressure. Here are the parts I'm ordering.
ACE Pipe High Pressure Pump To Block *Front Section Of Front Pipe* V8 (Britpart) RQB000270
ACE Pipe Collet (Britpart) ANR6700
ACE Pipe Special Washer (Britpart) RYF100420 *Bag Of 4*
Everything else looks good and I only want to replace this hose. Nothing else. Can I do this myself and connect it without removing the wheel or other parts. I have a steering guard.
Please help, I'm over landing. I need to drive it out of here. Everyone rejects the vehicle. They like the way it looks but refuse to work on it. Everyone rejects it. Please help.
I need to replace this hose myself in a parking space.
