ACE problem
Old 03-25-2007 | 12:49 PM
helievacpilot's Avatar
5th Gear
Default ACE problem
99 Disco II. My ACE pump is leaking pretty badly from the shaft seal. I have done a fluid replacement with the Lucas additive with no improvement except for a reduction in noise. I would really like to avoid having to shell out 500.00 for a new pump. Is there a seal kit out there so that I could fix it, or someone who re-builds them?
Thanks - Bill
Old 03-25-2007 | 12:55 PM
Default RE: ACE problem
Call your local dealers parts dept to see if there is a reseal kit available.
If not then consider going to, http://www.roverlandparts.com/ and buying a good guaranteed used ACE pump.
If you open up the system, make sure to not allow any more fluid then possible to drain out. If it drains to low, you will need to take it to the dealer and have him hook up their test book to purge the system after the pump replacement, BIG $$$'s.
Mike
Old 03-25-2007 | 06:15 PM
5th Gear
Thanks for the info. My wife would like to keep the ACE for now. Mike, I read your reply on the other forum. Obviously, I would have to disconnect the lines to the pump to remove it. Am I not ensuring myself a trip to the dealer to purge the system?
Thanks - Bill[/align]
Tin_Man
04-12-2014 12:12 PM
thehrdway
04-26-2011 02:41 PM
tbuckt007
04-13-2010 12:46 PM
Bobster
03-18-2009 08:53 PM
alrd
11-17-2006 12:25 PM
