ACE Suspension??
on
RE: ACE Suspension??
ACE was avery expensive o[tion and a good one at that, usually came with the SLS rear air suspension.
Easy way to tell if you have ACE is to look at your power steering reservor, do you have another reservor back to back, if so you have ACE. Then crawl under the r/f wheel and look at your sway bar, you will see a hydralic ram attached to it and well as to the rear sway bar. I would suggest that if you just bought this truck you send me your tele number so I can tell you how to service the ACE.
Mike
mikeljacobs@comcast.net
Mike
ORIGINAL: Disco Mike
Mike
Mike
________
on
ORIGINAL: phatduc
DMike or anyone with the know-how: could you post the DIY on servcing the ACE system? Thanks, Duc
Mike
Mike
