ACE system questions
on
Chris. I have ACE on my truck and you will unhappily realize why it was disconnected. The systems benefits do not out weigh it's flaws (mainly noisy whining) my suggestion is to to rover and ask them to shut off the system on the computer. The light will go away. Mine is on it costs about $150 to do it. Seriously though it sounds to me that it was disconnected for a reason. My car feels free without it!
The benefit far out weigh the cost of a bad pump.
ACE filter? Forgive me cause I'm new with Rovers but I just flushed my ACE/PWR steering the other day and did not know anything about a filter. Do tell me more. This thing is a whinny little booger. Sounds like a bearing going out in it. How loud should I expect normal to be. I am spoiled with the ACE (do not wanna disconnect it) This truck handles unreal!
thanks
I believe the filter is in the valve block on the right frame rail between the front/rear doors. You should be able to look it up in the RAVE manual. The filter is expensive and last time I heard you could spray-clean it with solvent, like brake cleaner. Mike will correct me if I'm wrong.
your right in your desription of where it is, its under the big hex cover in the bottom of the ACE valve block, however, 6 out 10 people cannot get them undone, so either end up "rounding" of the cover or leaving it well alone
