Added a 2004 D2 to the family !
so excited to have finally found the D2 we were looking for. The wife, 2 daughters, and myself are all sporting white Rovers, so our new off-road project had to fit in. Once we powder coat the wheels black, it will fit right in. Does anyone know if there is a retrofit kit for automatic headlights? The inly
issue I’ve had so far is forgetting to turn the headlights off because all of the other Rivers are automatic. Also, I noticed this model does not have daytime running lights.
![](https://cimg9.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/1b397752_bb84_423f_86ec_7f216a020b29_2790a48b9f67e4d9ce8bc16c90d653e1220fb9a6.jpeg)
I had to get the daytime running light option turned on when I moved from the States to Canada. It is possible.
A DRL relay (with the green strip) needs to be added to the fuse block. I then used my Nanocom unit to program the BCU to turn on the option. If you do not have a a Land Rover specific programmer, you can take it to a dealership or LR independent repair shop to do this. It should not take more than a few minutes to re-program it.
No Doubt (02-06-2019)
