Advice for a new Disco owner
Welcome, get the basics done :
Transfer Case and Differential oil changed
Front and rear drive shafts check and lubricated
Get a cheap blue tooth ELM 327 ODB adaptor and Torque for your cell phone and monitor your engine temps - This is critical as the dash gauge is just an idiot light and you need to know your cooling system is working correctly, ignore if you have a diesel engine. The V8 is a sleeved aluminum engine significant engine overheats can lead to failed head gaskets or worst case engines.
What Richard said.
Each of the four Dll's we've owned were either empty or extremely low on transfer case fluid. For some reason...it gets overlooked during services/oil changes.
Congrats, on the new purchase. Nice looking rover. One thing about the Dll, it's a vehicle that needs its hood opened once in a while, weekly preferably. Just pop the hood, check fluids and look for anything unusual. Listening is helpful too...strange noises need to be addressed. Maintenance of the front driveshaft is important also, make sure it is lubracated (if greaseable style...which l would purchase if it doesn't have one) and in good working order.
Good luck with your new ride.
@Sofia Berinstein And we all forgot one thing whether you drive off road or not once a month:
The process to get that lever to move is easy:
The object of the above step is to unload the gears and drivetrain - you can feel it but I can not really describe it but it generally works
The 1st few times you do this things may be stiff that is expected if the transfer case has not been out of high range in a long time
- Put the transfer case in Low drive a 100 meters
- If you have no CDL then Back to high and drive 100 meters
- If you have CDL push the lever over to the left drive 100 meters
- Push down drive 100 meters
- Then back to the right Drive 100 meters
- Do this pattern 2 or 3 times a parking lot is fine and you do not need any speed.
- Stop put your Disco in Neutral
- Push the Hi/Low lever firmly in the direction you want to go
Hi Sofia, I've also got a new to me white disco. Welcome!
I'm also trying to get my car caught up on maintenance. I've found Atlantic British's Maintenance schedule very helpful- just make an account on their site. I've printed it out and am checking it against service records provided and on mycarfax.com (free).
Which service items would one recommend, if for example, a car has basically sat for 2-3 years only putting on 10k miles in that time?
transfer case maintenance 3 years ago (not sure if differential is done at that time also). oil 3 years ago. brake fluids done 2 years ago. transmission serviced 12k miles ago. So all under recommended milage- but some time has passed.
What Richard said.
Welcome. If you are not mechanically inclined take the info on this board and tell your mechanic exactly what you want done
most mechanics don’t know these trucks and the common issues with them
if you tell them exactly what you want done it’s better
