ADVICE: Terrafirma Suspension Kits
Old 12-01-2018 | 10:24 AM
Dave03S's Avatar
I should also add if your steering damper is OG, replacing that with the TF unit will dramatically improve the ride and handling of your truck.
Old 12-01-2018 | 11:02 AM
ctfulmer's Avatar
Thanks!
Old 09-05-2019 | 11:59 PM
Carlos Man's Avatar
Originally Posted by escott16
Also if you have 18” wheels like I do i went up to 275/65r18 no rubbing, but I like many didn’t want to give up my 18” wheels I just love the look of them and I’m not a serious off-roader , but I think when my ko2 tires wear out I’ll be switching to 16” I just want a wider stance and make it look more beefy
just got my TF MD kit and looking to buy your tire size. Got any pics?
my D2 is stock with 18’s aswell
Old 09-06-2019 | 11:18 AM
jdbayer's Avatar
Here is mine. 2" TF lift with 275/65-18 KO2. The other pic is with the stock tires on it, they just look funny.
Carlos Man (09-06-2019)
Old 09-06-2019 | 11:56 AM
Carlos Man's Avatar
No trimming or rubbing ?
Old 09-06-2019 | 12:47 PM
jdbayer's Avatar
No trimming, no rubbing.
Old 09-06-2019 | 02:28 PM
Richard Gallant's Avatar
My 04 Terrafirma Medium and OME shocks 245/75/16 tires
Old 09-06-2019 | 07:50 PM
Nosugar0carbs's Avatar
2004 as well. OME shocks all around, OME rear springs and stock rear springs up front.255/55r20 Goodyear f1a/t. Does run on radius arm on full lock, however the Michelin’s I had prior didn’t rub. Picture is with 3 generators in the back.
Old 09-07-2019 | 06:40 PM
Carlos Man's Avatar
Thanks for all the input.
couple more questions
should I buy new front spring isolators (rubber boots) and the rear rubber spring silencers? Just wondering anyone has has them tear break or brittle during install.
also any other tips or buys that could improve, help, or break that I should have handy for my instal?
Old 09-07-2019 | 07:39 PM
jdbayer's Avatar
The only think I had to figure out on my install was I had to unbolt the front driveshaft. I used the bottle jack method but the driveshaft was pushing against a bar under there. Once I disconnected the driveshaft everything went smooth. It took 4 hours to do it alone.
Quick Reply: ADVICE: Terrafirma Suspension Kits
