Advise on frame replacement
I feel for your situation. I have had my beloved Disco since 2008 and I’m at a crossroads as to what to do with it. This past summer I had her frame patched up but was considering hiring someone to swap out the chassis, prior to finding a welder who would tackle the patch job. She has a few issues and I’m attached to her. I do know that there is no way that I could tackle a frame swap by myself as I just don’t have the mechanical skills, the equipment, the space, or herculean power.
If you can stay atop mechanical issues and know that you’ll be driving it for a long time to come, I’d invest the time and $$ into getting her frame done right (galvanized chassis), whether you do it yourself or hire someone else to do it. There are a lot of DII naysayers out there but also an equal amount who love them all the same. I vote for the fix.
i can do pretty much everything if I had the place and the idea on how to lift it safely. And the route I want to go would keep her running for years I would hope.
I agree we love out baby and she runs and ride great just have the normal stuff and yeah the place to do it and how is always the issue.
They are out there, and cheap. Gut what you won't use, coat the frame, and build one from the 2 of them.
You can rent an engine crane to get the engine out, or buy one at Harbor Freight for a couple hundred bucks.
If you're driveway is gravel, Tractor Supply has 1"x4'x6' heavy rubber mats.
I have one in front of the concrete coming out of my garage, and use it for just that purpose.
Another good writeup on this that's worth reading:
A Fix For Land Rover Discovery II Frame Rot / Rust - JE Robison Service - Bosch Car Service Specialists ? the blog
I would consider it but mine stops about midway from the rear doors
so this could be an option
https://www.roversnorth.com/parts/pl...y_ii_1999_2004
but 58" is cutting it close
Yeah, I just didn't know the cost delta between swapping a frame and patching. If anyone has had this priced out, I'd love to know more.
For your situation, I think the swap, particularly without a lift, would be one of the most difficult projects to tackle yourself. It might also be costly to source a donor truck, since most of those with desirable frames would be in drier, warmer parts of the country, so you might need to ship. I have a weird habit of peeking under the rear bumper of Disco 2s that I see, and it's a very widespread problem in the Northeast.
