Aftermarket bumper + fender liners
Old 02-19-2012 | 07:06 AM
ebg18t's Avatar
Default Aftermarket bumper + fender liners
When you install an aftermarket bumper like the HLC do you retain the lower plastic fender liners?
When y'all install 33" tires do you guys just remove these lower plastic liner pieces?
Old 02-19-2012 | 09:14 AM
You don't or shouldn't remove the liners or a lot of rust will be in your future.
Remember if you get to playing in the mud, both your diffs only have 2 spider gears and won't hold up to too much abuse, ought to be looking towards some lockers to fix that problem.
By the way, have you rebuilt or replaced your front drive shaft yet so it won't fail and take your tranny with it?
Old 02-19-2012 | 04:10 PM
ebg18t's Avatar
Mike - I am running Tom Woods prop shafts front and rear. I ordered Tru-Trac for front and rear diffs.
I guess I will just trim the lower plastic fender liners where the tires rub/hit slightly.
Old 02-19-2012 | 04:11 PM
DiscoRover007's Avatar
Damn your Discovery is going to be a badass truck.
Old 03-02-2012 | 05:14 PM
jbarrios60's Avatar
Default 03
Is the drive shaft also an issue for 03-04?
AB a new replacement but ends at 02
Old 03-02-2012 | 05:19 PM
Kalel's Avatar
Yes they are. If yours has not been replaced, do it soon.
Old 03-02-2012 | 05:40 PM
yloDiscoII's Avatar
Originally Posted by ebg18t
....I guess I will just trim the lower plastic fender liners where the tires rub/hit slightly.
Just, just trim he little edge of that rubs and call it good.
Old 03-02-2012 | 08:59 PM
ebg18t's Avatar
Thanks. I wanted it dependable for use in the desert for a couple week photo trips. Been trying to build it up tight the first time.
I ordered the winch and 6 PIAA 520 ATP lights so those shoud be here this week, truck shoud be ready soon.
redsoxvw
10-31-2014 10:33 AM
coldstart
02-17-2013 03:53 PM
aarongregor
04-25-2012 04:59 PM
clandrovers
09-07-2010 05:59 PM
GeoffW
04-07-2005 10:59 PM
Quick Reply: Aftermarket bumper + fender liners
