age old question. no flaming please. just suggestions.
so my 03 disco transmission is electronically controlled by a computer? am i understanding that right? and thats why engine swaps aren't doable?
if thats the only case, i would love to put a Jeep 4.0 or GM 4.3 and compatible auto trans in mine.
Anything can be welded into a car that has a traditional frame. Things to consider in a swap are exhaust line routing, firewall and radiator clearance and accessory devices that rely on the native engine.
For instance you will have a hard time mounting pumps and etc to your block without the means to fabricate brackets. I've done a lot of engine swaps and each time little things like power steering pumps kill you.
Imagine mating rover power steering lines to a 4.0L PS pump. First it's hard to find people willing to make the hoses, second it may not supply the required pressure. Next things like...do you want AC?
I think the biggest issue on swaps is the exhaust, when you pick an engine that people make aftermarket headers for it's easy. When you look at a 4.3 which doesn't have center dump manifolds it becomes tricky to route those lines past the firewall without a tig welder and some serious skills.
the transmission in our trucks is one of the best built pieces of our trucks. to get rid of it to do an engine swap is just stupid IMHO... if you want a different engine get a different truck because the swap is just a complete waste of time and money for these trucks.
not to mention putting a jeep engine in a land rover is possibly the most offensive and absurd thing i ever have heard.
What are you trying to accomplish by doing this? I am sure this guy is looking for a local sale (he is kind of local to me) but this may give you some other ideas.:
http://phoenix.craigslist.org/nph/pts/1496272115.html
keep in mind my 97 stock horsepower is rated at 182 HP @ 4,750 rpm. and this 5 liter is rated at 300 HP
It's unfortunate that some of our Rovers (notice that I didn't say all) will have serious issues that we've grown to take for granted in other cars.
I'd be pissed if my oil pump and head gaskets both failed before 60k in a Toyota, for instance.
However, we have Rovers because we love them. We tacitly accept their shortcomings because the intrinsic value of owning one outweighs driving something else.
but in a disco the 4.0 will in all likelihood be too long and the firewall will need to be modified. the loss in torques will be enough to seriously hinder the weight of the disco. the electronics will not work and even if they did you would most likely see a loss in MPG's.
the lesson here is that rover used a certain engine and tranny combo for a reason. stick with it.
