Air to Coil Conversion - 2000 Disco II
I have a 2000 Disco II and would like to convert from the self-leveling suspension to coil - are there any instructions or videos in the forum? Recommendations on how-to and coils/shocks used are welcomed. Thanks!!
Get your SLABS programmed for coils, remove SLS bags, drill/tap lower coil plate holes, install coils, unplug all SLS wiring in the SLS box under the D2 on the drivers side & remove the relay for it under the hood. |
If yours is working, why not just keep it. The ride will never be better than the air springs and If you want a lift you can always add the spring spacers from Toddco.
