Air to Coil Conversion - 2000 Disco II
Old Oct 29, 2018 | 02:14 PM
droddisco's Avatar
7th Gear
Question Air to Coil Conversion - 2000 Disco II
I have a 2000 Disco II and would like to convert from the self-leveling suspension to coil - are there any instructions or videos in the forum? Recommendations on how-to and coils/shocks used are welcomed. Thanks!!
Old Oct 29, 2018 | 02:43 PM
Best4x4's Avatar
Get your SLABS programmed for coils, remove SLS bags, drill/tap lower coil plate holes, install coils, unplug all SLS wiring in the SLS box under the D2 on the drivers side & remove the relay for it under the hood.
Old Oct 29, 2018 | 03:49 PM
Big Jim Swade's Avatar
If yours is working, why not just keep it. The ride will never be better than the air springs and If you want a lift you can always add the spring spacers from Toddco.
Bulax99
Jul 22, 2018 09:21 PM
DiscoDubs
Oct 12, 2012 07:20 PM
buick215
Jun 17, 2011 01:31 PM
tlester72
Dec 28, 2007 04:20 PM
Lee
Aug 25, 2006 11:37 AM
