Air suspension
Air suspension
Hey everyone,
I recently bought a disco two and I've had no problems with it so far, until this morning. So my drivers side air suspension is all the way inflated and I cant put it down. I'm at a loss on what to do. I want to try and fix it myself but have no idea how. If anyone has any idea as to what happened or how to fix it, that would be very appreciated!
If the bag doesn't deflate when you go over (I think) 15mph, it sounds like there's probably something wrong with one of the air valves. I don't know of a manual release for them but you could always just loosen the fitting on the air pipe at the bag so that it slowly deflates.
My guess is that you have a faulty height sensor that told the SLABS system that side was low, so the pump came on to pump it up. You will need a scanner that can read the sensor heights and see if there any error codes. If you don't have one you can rent one here: https://extinctmotorsports.com/nanoc...eek-rental-55/
