Alternator removal and installation
I am trying to replace my alternator on an 01 Disco II. I removed the two 15mm locating bolts and 10mm bolt. There are dowels holding the alternator to the locating holes on the bracket. How do you get these out?
Those "dowels" are prob just the metal pieces that press into the alt when you tighten the bolts. Once you have those two bolts out you may have to pry the alt out of the mounting bracket.
This. Pry bar + brute force = Alternator out. Broke some other stuff on the way out though. Collateral damage.
Broke this line trying to get the alternator out.
http://www.roverparts.com/Parts/SQB103300G.cfm
Damn!
Snapped the line on the negative wire. Shouldn't be too bad to get that back together.
Damn!
SuperSport
Dec 6, 2019 01:18 PM
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
