Amigos. I’ll give the symptoms you guess the codes. Winner gets nothing
Old Nov 15, 2019 | 05:26 PM
Frank4's Avatar
Default Amigos. I’ll give the symptoms you guess the codes. Winner gets nothing
Sometimes the Amigos come on when the truck is started sometimes not. If they aren’t on when started they can be triggered when hitting bump or pothole complete with the chime and everything. Over the past 3 days the Amigos have appeared 6-7 times.
About to read the codes, let’s hear hear some predictions
Old Nov 15, 2019 | 05:35 PM
redwhitekat's Avatar
One thing I noticed one day was if your foot is on the brakes while your starting the disco it will throw the amigos.
Old Nov 15, 2019 | 06:45 PM
Frank4's Avatar
Interesting point but my DII has a new ignition switch from Lucky8 that doesn’t require your foot to be in the brake when starting.
Old Nov 15, 2019 | 07:22 PM
Best4x4's Avatar
Sounds like a Ground fault code
Old Nov 15, 2019 | 08:17 PM
Friday Night Disco's Avatar
Right rear electrical fault
Old Nov 15, 2019 | 09:14 PM
None do I just had my foot on the brake by accident
Old Nov 18, 2019 | 07:30 PM
merebel's Avatar
Drivers kick panel the grounds there check to make sure they are tight as that also caused my issues so hitting bumps caused strange codes and lights
Old Nov 18, 2019 | 08:23 PM
Best4x4's Avatar
The internal connection inside the WABCO unit which Option B bypasses will cause the 3 Amigo’s to come & go as well.
Old Dec 6, 2019 | 03:28 PM
Frank4's Avatar
Shuttle Valve!!
Old Dec 7, 2019 | 02:19 AM
The Deputy's Avatar
Do we at least get a trophy for participating? I mean, this is the 21st century...where everyone's a winner!...even the losers.
DiscoNickBK
Oct 1, 2018 07:27 AM
Bulax99
Jun 3, 2018 09:52 PM
GadgetRick
Feb 9, 2012 10:18 PM
lampertt
Nov 23, 2010 11:51 AM
tastandish
Jun 27, 2009 07:22 PM
