Amount needed to re-fill tranny?
It varies a bit, there will always be some left in the tranny after you drain it. If you're using the lucas additive, you won't need 6 quarts of ATF. I think to fill I used the bottle of lucas and about 4 1/2 quarts of ATF. Never hurts to have a little extra though, it's easy to spill when you're under there unless you've got it up on a lift...i'm not that lucky
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
DiscoPhipps78
06-15-2018 03:11 AM
