Antifreeze pooling on top of valve cover....?
Old 04-02-2014, 07:13 AM
drowssap's Avatar
try running a file over the bottom of the TB to be sure everything is square
Old 04-04-2014, 11:57 PM
Retroman1969's Avatar
Thanks everyone for the advice.
It's at the Rover shop now getting a bypass. They found no other leaks.
I had them check the whole vehicle out while they were at it. Needs a wheel sensor to fix the "three amigos", a vacuum line to fix the cruise control, and a brake job (brakes were beyond shot). The prop shaft has already been converted, so I lucked out there.
All in all, not much to have to do to a fairly fancy vehicle that has been used and abused heavily for 128,000 miles.
Old 04-05-2014, 05:45 PM
kfx4001442's Avatar
Good to hear. Keep that shaft greased. Every oil change!
Old 04-06-2014, 09:05 PM
Will do, thank you!
You mean the car, right?
NiteTrain
01-21-2010 02:41 PM
cosmickites
Defender
10-14-2008 08:40 AM
NiteTrain
05-21-2008 01:07 PM
OJs DNA
05-06-2008 10:18 PM
Quick Reply: Antifreeze pooling on top of valve cover....?
