Asking for Power Steering Advice
Recently it seems the power steering has become weak/non-existant. The rover has almost 180k on it 50k of which I've put on it. For all I know, the power steering components are original so I'm not surprised if it needs a new pump and hoses.
The fluid is dark and most likely needs to be flushed. I plan on starting there. It seems like there could be a leak due to some wet areas on some of the hoses, the steering box and drop arm but the fluid level never seems to drop. I'll be inspecting that better in the morning.
My Questions:
- How long can the steering box be expected to last? Can it be rebuilt? What are the common points/signs of failure?
- Is it necessary to replace the reservoir or can the integrated filter be cleaned?
- Is it worth trying to rebuild the pump, get a salvaged one or go for new?
My Questions:
Took it all apart today.
The pump gasket was in sorry shape but other than that, the internals seemed fine.
The reservoir filter was clogged up with black gunk. Not sure what the cause of that is.
The hoses seem to be ok. At least they don't seem to be leaking.
I'm thinking that the reduced flow from the reservoir and the leaky gasket are the culprit to my lack of power steering. Now I just have to get a rebuild kit or new pump and a reservoir that doesn't have holes poked in the filter from a turkey baster.
Should've been seeing significant return fluid flow to reservoir if filter/pump good. Your over due for reservoir change per D2 mx schedule. Assume that is because of non-serviceable filter. Spend the little extra for a new one.
https://landrovermerriamparts.com/parts/2001/Land%20Rover/Discovery/Series%20II%20SE?siteid=215719&vehicleid=203584§io n=STEERING&group=STEERING%20GEAR%20%26%20LINKAGE&s ubgroup=PUMP%20%26%20HOSES&component=P%2FS%20reser voir
• The Power Steering/ ACE fluid reservoir should be replaced at 150,000 miles
(250,000 kilometers)
Is there any follow up on this? I have a similar issue, but power steering seems to work fine at speed (hard to tell I know since steering always gets easier with speed) or higher engine rpm. Slow speed, low rpm, steering is VERY heavy.
Can I test this by shifting in to neutral and making some turns with higher rpms?
I have PS fluid and a new belt to put on, but haven't had time to do so just yet.
New owner of an '03 SE, and starting to work my way through the 60k mile check (126k on the Disco), as well as a few other things...
Thanks!
Thanks!
Chasen7,
Just rev the engine in park and see if your steering gets easier. I had this issue a few months ago, and it was caused by a tired/worn pump. Increased RPM compensated for the reduced flow/pressure. Replaced with a junkyard unit, and all has been well since.
If you need to be moving for the steering to get easier, this is typical of total loss of power steering and may have a different cause. (though likely still a pump issue)
When I took the pump apart to change the gasket, I noticed the valve was stuck. This explains why it was hard to turn one way but not the other. I fixed that and proceeded to rebuild the pump with new gaskets. Unfortunately, when putting the rear cover back on, I noticed a crack formed in the cover and the pump was hard to turn. Not sure what happened there but I ended up buying a new pump and now everything works great without any leaks.
If I remember right, the shaft can move inside the pump. I have seen the rear covers get cracked like that before. You're probably better off with a new or rebuilt one anyway. They are such a simple design, but they're so easy to mess up. There's probably a certain measurement from the front of the shaft to the front of the pump or something like that. It sucks that you went to through all that just to have that happen.
Glad you got it working!
Thanks for posting the final fix.
