Automatic Transmission flashing m & s symbols
Long story short... O2 sensor wire melted after being caught in driveshaft and then pushed into exhaust pipe... replaced wire and O2 sensor. Kept getting O2 sensor fault code turned out to be a bad fuse box... just replaced fuse box... cleared codes and took it for a drive... now the M & S symbols are flashing when I put it in gear and the transmission while it shifts into reverse and drive only goes into 2nd gear and will not shift up or down while driving. I haven't checked the codes yet but am I correct in assuming it is most likely going to be the TCU?
rob bartleman (03-10-2024)
There are 14 different faults that can trigger the M&S lights to illuminate together. You can't know the cause without getting the codes read.
That said, and as others have written here, the most common cause of the flashing M&S lights is a voltage anomaly. Clean and check and double-check the battery terminals to ensure they are clean and secure.
If that doesn't address the problem, get the transmission codes read, or at least review the RAVE workshop manual to look for symptoms that match what you are observing.
rob bartleman (03-12-2024)
