Axle Identification
Hello - new to me Disco, stats in sig. I'm going to get it ready for my daughter to drive when she turns 16 in May.
I tried several combinations of searches and wasn't able to determine an answer to my question. How do I know if my axles have posi/trac-lok/limited slip without pulling a diff cover? I'm going to go purchase the fluids Mike wrote up in the sticky to change all of them, but thought if I could determine whether I needed fish oil or not first it would save me a trip. Is there any way to tell just by kneeling at the bumper and looking at the pumpkin? Thanks. |
Rovers never had any form of positraction, only open Diffs.
First off there is NO inspection cover, the diff comes out as one unit and can be done with the truck sitting on the ground.
Now to answer your question, no, it is NOT limited slip, it is a open diff, you have three open diffs, front, rear, and t-case. These trucks are full time four wheel drive with a center locking differential (transfer case), when the CDL is locked equal power goes to the front and rear axles and the truck is virtually unstoppable. The t-case and axles take the same fluid. She MUST use premium gas, if she does not she will lose MPG and toast the engine in no time flat. |
Thanks to you both - straight multi-weight it is then. I'm 6'6" and closing fast on 50...the fewer times I have to get on my hands and knees the better. :p It will be several weeks before I can take it to the local Air Force Base and get it on a lift. I did do my homework on the gas Spike - filled up with BP 93.
While I was at Auto Zone this evening I saw that they have several brands to choose from and several "levels" of oil. I know your partial to Royal Purple Mike, but they also have a high dollar Valvoline and a couple grades of Lucas oils (speaking diffs now...) Your thoughts? |
The oil is your choice, I would do an ATF flush before changing out the oil.
Here is your homework list. Mike 1 Oil filter, K&N 3001 or Mobil 1- 301 1 Factory air filter 6 Qts. of engine oil 2 feet of 3/16th vacuum tube 2 feet of 5/16th vacuum tube 12 Qts. of ATF 7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use 3 Pints of synthetic DOT 4 Brake fluid 2 Qts of synthetic Power steering fluid 2 Gallons of OAT, orange coolant, also called DexCool 1 Bottle of Lucas Power Steering additive 1 Bottle of Lucas Transmission additive 1 Can of Spray Carb. Spray 1 Can Of Brake cleaner 8 Spark Plugs, I use Bosch Platinum Plus 4's 1 Set of Magnacor 8mm plug wires 1 Serpentine belt 2 Bottles of SeaFoam gas additive 1 T/Stat 1 bottle of WaterWetter or Purple Ice Hoses and belts, as necessary 60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased Bleed the brakes Flush and change the power steering fluid adding one bottle of additive Service the tranny adding one bottle of additive Change the coolant and t/stat Do an engine flush before changing the oil Do an induction cleaning Clean the throttle body Add fuel additive to full gas tank Change both of the diffs fluid Change the t/case oil Replace the plugs and wires Replace the air filter Lube all the drive shaft grease fitting including the 2 slip shafts Do full inspection of brakes, hoses, bushings etc. Hopefully I didn't leave anything out. |
I am partial to RP, but there are lots of good synthetics out there. Lucas being one of them. Not as good, mid you, but good. Just make sure you use synthetic.
If you find water in the diffs, check the breather tubes for blockage and cracks. Make sure and service the transfer cae while you are in there. The fill hole is a little harder to get to, but while you have it up..... Your year takes ATF in the power steering fluid reservoir. If you put in ps fluid it will leak. If it is leaking now, cut off the factory clamps and use new worm type hose clamps. |
With the T-Case fill plug, I had to start loosening it with a 1/2 inch ratchet and then take off the ratchet before I got it backed out too far or it would have been trapped.
I backed it out the rest of the way gently with a pair of vise grips. |
If you use 85w-140 gear lube your truck will be quieter.
I had to mention the gas, so many people buy these trucks without doing their homework. |
