Battery light?
Old 05-13-2008 | 07:48 PM
tailchaser0527's Avatar
Default RE: Battery light?
On my way there now. I'll post back in an hour with the results.
Old 05-13-2008 | 08:56 PM
went to AutoZone, battery has 12.5 volts, and shows good. Charging system is putting out 13.9v and 13.5 under a load. But thebattery light wasn't on at the time, it was on upon cranking, and stayed on until I rev'd the motor up in neutral at a stop light. It hasn't come on since then.[:@]
Old 05-13-2008 | 09:18 PM
13.5 under load is under spec's, granted, not by much but under.
Old 05-13-2008 | 09:40 PM
Alright, it's got to be the regulator (new alternator time?).. As I went to leave my dad's house, the battery light was on again. He has a Schumachersystem tester in his garage. With the battery light on the system's only putting out 12.5v (the same as the battery), Got the light to go out, same as before, and then it was putting out 14v.
Old 05-13-2008 | 09:43 PM
Sounds like its time to bite the bullet and buy a new alternator.
Old 05-13-2008 | 10:13 PM
roverguy7's Avatar
make sure that your small wire to the back of the alt is not getting shorted to ground, if it does, the light will be on and it will not charge, have any work done reletivly recently before the light started comming on?
Old 05-14-2008 | 08:05 AM
Landzu's Avatar
ORIGINAL: Spike555
Most times alternators do not go out all at once,,,so Spike is right.
nateandnikki
07-02-2013 07:38 AM
xoo00oox
01-11-2013 07:23 AM
marlymarl
05-28-2011 11:34 PM
arrkerr
12-14-2005 11:06 AM
robdis96
01-30-2005 09:45 PM
