A better tire carrier?
I had to cut and relocate my tire carrier UP in order to place my larger than stock spare, and was initially concerned that the the notch I cut to accommodate the wiper arm would crack. Nope; the top bolt holes (both sides) cracked. Our tire carriers are made of very brittle metal, just FYI. I heard squeaking coming from the rear and stopped just in time to keep my heavy tire from falling off on the interstate. I had to remove the tire in a suit and white shirt. Sadly, this leaves me with no tire carrier. I can get another one on eBay or but I expect similar results. A bumper swing carrier seems like overkill (and the price is ridiculous); has anyone run across a reasonably priced tire carrier that will work with bigger, heavier tires (33")?
Best,
Charlie V
Best,
Charlie V
I just flipped mine upside down and drilled two new holes for the middle screws. As far as the wiper, I just loosened it and rotated it up. No cutting. I fit a 33" tire, just barely, as it rubs the stock bumper just a bit. If I has help it probably wouldn't rub, but I couldn't hold the carrier "up" while tightening it.
Best,
Charlie V
