Bolt Covers
Old May 16, 2005 | 03:33 AM
kumbhani123's Avatar
Default Bolt Covers
Anyone know how to remove these things? i had a flat tire and **** i spent 2/3s of the time just removing those things... not to mention i ruined about 3.. to tell you the truth if there is no special way to remove them, im going to break them all off... They arn't worth the look.
Old May 16, 2005 | 12:42 PM
BridgeRover's Avatar
7th Gear
Default RE: Bolt Covers
I'm not surw what year you have, but my bolts don't have covers and I just used a regular torque wrench to get them off and it didn't really damage anything. They are so cheap anyway to replace.
Old May 16, 2005 | 03:53 PM
mikemeyer0's Avatar
DON'T REMOVE THE COVERS!!!!!
Leave the covers on they are not ment to be removed. You lug wrench for you LR should fit on them if not there prolly a lil bent up. Carry a metric socket that is one size bigger thatfits snug.
Old May 17, 2005 | 11:08 AM
khtemple's Avatar
I had a similar experience. If a mechanic touched your tires recently, they put the lugs on too tight with a pneumatic wrench. I ripped a lug nut cover completely off trying to remove the nut (with no success). At best it is a pain in the butt. At worst, if you had a flat in a remote area, it could be a real sticky situation if you couldn't get the wheel off to change the tire. Your mechanic owes you an apology. Lug nuts aren't cheap, and now I have to replace one.
Old Oct 10, 2005 | 01:42 PM
surfrover's Avatar
hey, i bought my 97 lr disco sd from a private seller and the original lug wrench had been lost. what size socket should i use to get the lug nuts and those covers off? or should i just get a new wrench from a dealer?
Old Oct 10, 2005 | 11:08 PM
Bait's Avatar
27 mm Socket ONLY ! They are not cheap in the States. A lug is around US $20 each.
focusontheworld
Oct 21, 2012 01:00 AM
JKK
Jan 10, 2006 01:31 AM
Lebowski87
Nov 9, 2005 06:11 PM
martinezrubio
Aug 10, 2005 10:56 AM
FarmerXJ
Jan 24, 2005 07:13 PM
