bolt pattern
Old Oct 12, 2006 | 01:13 PM
groundpounder's Avatar
Default bolt pattern
Greetings. What is the bolt pattern of a 1998 Disco 1? Looks HUGE! Thanks!
Old Oct 12, 2006 | 02:19 PM
Default RE: bolt pattern
You are right, it is huge, 5 on 6.5.
Trying to find some new wheels to fit it? Bit of a problem to find the right offset and a hole large enough to clear the hub.
Mike
Old Oct 12, 2006 | 03:09 PM
Thanks for the quick reply. Yeah, that's the biggest I've seen on a 5 bolt pattern.
I am just beginning to wonder what is going to be available out there. I'm such a Rover noob!
I'd like to find something a tad wider that also pushes things out a bit, so a little more offset and less backspacing. Just looking around a little.
Old Oct 12, 2006 | 03:14 PM
Here's another question:
are there any other vehicles that have that pattern? I know of none.
Might expand the search a little...
Old Oct 13, 2006 | 11:08 AM
Don't know, but remember it is not just the bolt pattern you must be concerend about but also the off set and the hub size.
Mike
Old Oct 13, 2006 | 06:28 PM
Yes, I know.
I'm hoping to find something with a larger offset.
Do you know what the hub diameter of a 98 Disco is?
Euphoric
LR2
Feb 4, 2012 02:41 PM
TraV300
Apr 29, 2007 11:01 AM
pwag
Jul 23, 2006 11:14 PM
surfrover
Apr 18, 2006 04:12 AM
sclarkie
Aug 9, 2005 04:01 PM
