Book time to replace front and rear diffs?
My alldata script has expired... I'm curious, does anyone know the book time average for a shop to replace the front and rear diffs? I'm planning out a truetrack front/detroit rear job and am figuring out probably costs for installation/labor and associated parts ie. gaskets, fluids etc.
Thanks all!
ps. I'm also looking to go with a different ratio, 4.11 perhaps unless someone could recommend other, to regain some loss I now have with my oversized tires. I can barely merge infront of a timber toating 18 wheeler haha.
Thanks all!
I honestly have no idea what a shop time would be, but I can not imagine it could take more than 2 hrs per. that's about what it took me. axle seals, o rings, gear oil, nylocks, and sealant (right stuff) are the only consumables that are disturbed, unless you count pads. first two optional.
5 will work, I'll figure to budget at least $500 then for the install, thanks all! Hopefully it's just a pop in and out operation. Anyone have any idea if anything patricular needs to be done if I grab a pair with different gearing? I remember when I got 4.11's for my trans am I needed a different paddle kit to make room for them to bolt in, might be a torsen thing though
