Bought Blower Still Nothing
99 Disco 2
76k miles
So I thought the blower went out..bought a new one. Still nothing. I can hear a mechanical switching sound when I power the hvac on and off..and it makes the noise periodically while driving. Is this a relay switch?
Checked the fuses of course, they all checked out. I'm really stumped. What could it be?
-W
76k miles
-W
RE: Bought Blower Still Nothing
Hey Mac,
I have a Rave CD and I searched through it for "resistor" I'm having a hard time locating what you just found. I read something similar but it was talking about the resistor that handles the rear ventilation. It mentioned something about a fuse. And if it was a bad fuse, the blower wouldn't work EXCEPT when you dial the fan motor up to it's highest setting. Then it would work. Not the case with my prob. But then again this fuse idea I found in Rave might not be the same thing.
What did you search for on the Rave CD to find that?
-w
-w
Air conditioning-Repair-Blower Resistor. It didn't indicate that it was for rear air, but it is in the section for rear air. Couldn't hurt to check. There is also one under heating and ventilation that talks about the resistor pack. Heating and Ventilation-Repairs- Resistor pack power A/C.
I called Mike about this. He was a little stumped after talking with me and doing some troubleshooting. He suggested I buy a test light to see if power was actually getting to the blower.
I bought one and I think I'm too dumb to use it. I get the idea of how it works, but I don't know how to use it properly. I've poked around on the wiring and the terminals of the blower. Nothing. So I'm thinking I should use the test light on a terminal/wire that I know is live. Suggestions? I'm a little lost on this one. My lack of DIY is really showing..
