Bought Blower Still Nothing
RE: Bought Blower Still Nothing
Make sure you have the light installed on a good ground. I run a wire from the test light to the ground on the battery, that way I know it's good. Make sure the controls are on, obviously and check all the wires on the connectorto see which ones are hot. Then compare it to a wiring diagram.
The wire coming off the test light is only about a foot long, so I can't use the battery ground. I did find a bolt in the door hinge. I tried that, but still nothing. It's frustrating. I don't know if I put the AA battery in wrong or just not making a good contact or I'm not getting a good ground. uggh.
I know on my 88 Classic the resistor is under the passenger side dash area.I looked on the RAVE CD and I thinkit isbehind the glove box bucket. 1. Remove the screws holding the toe board and the toe board. 2. Remove the 4 screws removing the glove box. There should be a multi plug connected to the resistor and screws securing the resistor. It is on the CD under "Heating and Ventilation" >>"Repairs" >> "Resistor Pack"
OK. I finally got the test light to work. Turns out the battery in the light wasn't making a good connection. Now that the light works I decided to go out and try again on the Disco. Here's what happened:
1. Touched probe to hot wire with ignition off. Result: Lit up test light.
2. Touched probe to hot wire with ignition on. Result: Lit up test light.
3. Touched probe to hot wire with ignition on AND heater/ac on. Result: No light.
4. Turned heater back off, touched probe to hot wire. Result: Lit up test light.
So what does this mean?
just throwing this out, I am not positive, but if it is showing hot, it is not grounding out. This should mean the blower relay, if there is one, is ok, and your ground through the resistor pack (if I am right) is not making a good connection. It should still work, though, unless all of the resistors are open, or there is a loose wire.
I would take down the glove box and the trim under it and look for wires going into a plate on the ducting held in by 2 screws. Pull it out and take a look at it. The resistor packs are usually in the plenum so they can be cooled by the airflow...
Might have to take this one in....Did it just quit all of a sudden?
The Resistor Pack. Doesn't it control blower speed? Because, to my knowledge, the blower has two speeds: on and off. But the resistor controls the flow of electricity thus giving me control of blower speeds 1,2,3, and 4. Correct?
Therefore if the resistor failed or wasn't making a proper connection, wouldn't my blower just blow at top speed?
No, It has to go through the resistors. On low, it goes through the largest (least resistance) and then goes through more as the speed increases ( in parallel, dropping resistance ). They do it this way on the negative side to create the least amount of heat and power draw. Again, I am not positive it is wired this way. If I had a D2, I would go out and be able to tell you...If anyone wants to donate and 04 for the cause, let me know....
I would take your new test light and go through every fuse again. Test the one's in the engine bay as well....
Anything else not working?
