Brake Bleeding/Motive Bleeder
Are any of you using a Motive pressure bleeder? I have been using one for years on my BMW's and I ordered the universal apapter marked for Land Rover Disco II's on their website, the 1101 model. I put it together and get under the hood to find out it doesn't fit.
Any of you using a pressure bleeder on your DII? I have a 2002.
Thanks,
Chris
Thanks,
Chris
Weird. The BMW cap is a screw cap and the Land Rover cap has two tabs, does not screw down, just push down and turn.
what year is your disco? I'm trying to figure out what different typs of resevoirs there are out there on DII's.
Thanks
Thanks
It's an '03 and the cap looks identical to a 745 cap right down to the filter in the top of the reservoir. Just went out to make sure I wasn't having a false memory. I got my bleeder from BavAuto and have just used the quick connect cap it came with.
1. Add brake fluid to the Motive Power Brake Bleeder tank.
2. Firmly connect the supplied adapter to brake master cylinder and pump the Motive Power Brake Bleeder to pressurize.
3. Starting with the furthest away brake bleeder valve (typically on the rear of the vehicle), open brake bleeder valve and purge the air and old brake fluid from your brake system.
For more info visit: http://www.buybrakes.com/motive
