-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Brake / Cruise Control Issue (https://landroverforums.com/forum/discovery-ii-18/brake-cruise-control-issue-23269/)
jacklantern 07-07-2009 12:30 PM
Yesterday my cruise control stopped working, and my wife said that my brake lights appear to be on constantly. Would this be a brake light switch issue? If so, I'm seeing two different parts online - a brake pedal light switch and a harness brake light switch. Any suggestions on figuring out which may be the culprit? Thanks,
Steve
2001 Discovery II
nm50 07-07-2009 12:59 PM
It is indeed the brake light switch preventing the cc from working. I'm guessing it is the brake pedal light switch as that is what is used on most cars to disengage the cc. My jetta does the same thing occasionally.
jacklantern 07-07-2009 01:16 PM
how difficult is that bugger to get to?
nm50 07-07-2009 02:04 PM
not sure. i'm guessing it is down near the brake pedal as it is on most cars. check this link: http://www.landroverresource.com/doc...hop_Manual.pdf. if this doesn't get you the answer, it is likely in one of the links at this site: http://www.landroverresource.com/index.html.
good luck!
Disco Mike 07-07-2009 02:44 PM
You can order them at your local auto parts store.
