Brake / Cruise Control Issue
Old Jul 7, 2009 | 12:30 PM
jacklantern's Avatar
6th Gear
Default Brake / Cruise Control Issue
Yesterday my cruise control stopped working, and my wife said that my brake lights appear to be on constantly. Would this be a brake light switch issue? If so, I'm seeing two different parts online - a brake pedal light switch and a harness brake light switch. Any suggestions on figuring out which may be the culprit? Thanks,
Steve
2001 Discovery II
Old Jul 7, 2009 | 12:59 PM
nm50's Avatar
5th Gear
It is indeed the brake light switch preventing the cc from working. I'm guessing it is the brake pedal light switch as that is what is used on most cars to disengage the cc. My jetta does the same thing occasionally.
Old Jul 7, 2009 | 01:16 PM
6th Gear
how difficult is that bugger to get to?
Old Jul 7, 2009 | 02:04 PM
nm50's Avatar
5th Gear
not sure. i'm guessing it is down near the brake pedal as it is on most cars. check this link: http://www.landroverresource.com/doc...hop_Manual.pdf. if this doesn't get you the answer, it is likely in one of the links at this site: http://www.landroverresource.com/index.html.
good luck!
Old Jul 7, 2009 | 02:44 PM
You can order them at your local auto parts store.
Evan5291
Nov 21, 2017 07:59 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
Benhamtroll
Jan 18, 2009 08:01 PM
slangel
Oct 7, 2006 11:55 PM
madas
Aug 27, 2006 04:54 PM
