Broken front driveshaft - Should it still pull itself?
I have a 2000 Discovery II that just ticked over 100k miles. This past weekend the front driveshaft broke at the U joint on the transfer case end. The rear driveshaft is still in place and looks just fine. I am ordering a replacement driveshaft, but I did notice that the vehicle will not pull itself with the front driveshaft unhooked. Also in Park the vehicle still rolls freely. Is something more serious wrong that just the broken driveshaft, or is this normal behavior for this type of transfer case / diff?
RE: Broken front driveshaft - Should it still pull itself?
Thanks a million you guys. That's what I hoped was the case but I needed to hear it from someone else.
I am a little strapped at the moment so I had to go with a used part. I had a hell of a time finding one, so I finally went with a site that apparently networks a bunch of salvage yards together. I ended up getting the complete drive shaft for $250 including shipping. I normally get everything from Atlantic British and love their products and service so far, but like I say my wallet couldn't take the hit this time around.
on
Make sure you inspect the used drive shaft before installing. Make sure the new shaft has u-joints in that double card housing that have grease fitting, or you will need to replace them prior to installing th drive shaft. Also lube all the fittings including the slip shaft before you install it.
Good luck,
Mike
Good luck,
Mike
I'm a bit confused by your post Aaron. For your $250, do you get a newly overhauled driveshaft with new joints or do youget a used one with used, non-greasable joints? If the latter, there's a newly overhauled one on craigslist in Denver posted by a local driveline shopfor $300. You'd be better off going that route and paying the shipping.
http://denver.craigslist.org/pts/485960750.html
Cheers,
Dave
Cheers,
Dave
FYI, Geotrash and anyone else w/ an '04, when replacing your front driveshaft the part is different than the other Disco's. It's actually a slightly longer shaft than that on the other Disco II's, and accordingly more expensive. Had mine replaced about 2k ago, under warranty so it's a stock LR shaft w/out grease fittings. I plan on replacing the rear joints w/ greasable fittings in the spring.
on
The new 04 drive shafts finally have grease fittings from Rover, took them long enough. Also I would think the new longer shaft would be great for a lifted truck.
"Hi, same problem today with my 1999 Discovery II. Can you please clarify how to get this thing driving again while I wait for the part? I apologize but I am not smart on the acronyms. Thank you!" Send me your e-mail address and I'll send you a picture of the t/case and what to turn to engage your CDL.
Engage Disco II CDL
Can you send me the picture of the t/case so I can engage my cdl. It is a 1999 disco II whose front drive shaft broke today. My email address is pgkraemeriii@yahoo.com
