Brush Guard impact compression shocks
Ouch, after many years our Disco's front brush guard met a stationary object. no damage to the body. but it pushed the brush gaurd back an inch or two. I have not investigated underneath but am assuming that the brush guard is attached to compression shocks to absorb impact. Any instructions on how to reposition the brush guard (repressurize compression shocks) back to normal position? Everything else checks out fine except the headlight washers which were knocked out of position.
thanks,
Craig
thanks,
Craig
The holes in the brush guard (or bull bar for correct name ) and the chassis are a little "oversize", so if its hit then in can move quite a lot on the mountings, if you lossen the bolts off (2 each side) you will most likely find you can move it back to its original position quite easily and te-tighten the bolts up again. There is no compression shocks at all.
The tighter you can do the bolts up, the less it moves when you clout it.
smokinwheels
05-25-2021 11:11 PM
twaszak
06-27-2011 04:21 PM
