Brush Guard Lights
1st off, if factory, you need you have your high beams on to turn them on. Check all your connections and look to make sure the fuse under the hood (near that black box) is good. I'm having an issue with mine right now here I believe the relay (in that block box) is bad. See if you are getting power to the relay, and go from there. Should be either a bad switch, bad relay or bad lights. Make sure connections are clean too, and that all 8 pins for the relay are in and good.
Hi (first post)
I'm having the same issue. I have the aux light bar on top (4 helas). I have 2 factory switches inside on the left of the gauge cluster. Neither light up with or without the high beams on. The lights won't come on and as far as I can tell all fuses are good and I replaced the relays just incase. Fog lamps (front and rear) work. I plan on pulling the fuse box under the hood out to see if there is something lose or disconnected.
Are you serious about the 'asphalt sensor'? That would be the first for me but this my first LR and I've only had it a week.
JKFL03: You have a factory setup, or at least factory parts from your pictures. I bought some OEM lights on EBAY for cheap several years ago, and the OEM wiring kit from a dealer (not cheap). The best advise I can give is to download the RAVE manual, and get the installation instructions in the "accessory fitting instructions" section. By following the instructions for installing a new set, you should be able to determine if anything is missing from your setup. See where all of the wires connect, the fuses, relays, and grounds, then compare with what is in your vehicle.
