To Buy With A High Price or High Mileage 2019
Old Nov 14, 2019 | 04:59 AM
  #21
shanechevelle's Avatar
Originally Posted by earic23
Care to share why? What about 03? Perk of the 04 is the center locking diff w/o ghetto rigging anything, but if 04's are more problematic, I'd love to know why.
Engine issues are more prevalent.
Just swap the locking diff, it's not ghetto rigging anything, its putting parts on a drivetrain that was made for it.
Old Nov 14, 2019 | 10:32 AM
  #22
Broken08's Avatar
Originally Posted by shanechevelle
Personally I wouldnt buy any 04. 99-02 is my limit.
Living at elevation in CO I can tell you, I NEED a 4.6, but currently have a 4.0 2001. When this dies (if I ever let it) I'm going for an 03-04 for the extra power. At the basic elevation I live at, it is down over 20% on power from stock. Going over a mountain pass at 12000 feet...now you're down almost 40% on power, so I need all the power I can get.
That being said my 01 keeps on chugging along with only peripheral failures, not internal engine problems.
Old Nov 14, 2019 | 10:33 AM
  #23
Broken08's Avatar
Originally Posted by Sixpack577
03 And 04 had the C grade 4.6
The A and B grade 4.6 went in the Range Rovers.
The 4.6 is simply a 4.0 with a different crank and rods.
The C grade 4.6's of 03/04 apparently had alot of bad castings, as in one side of a water jacket was thick and sturdy, and the other was thin and weak. Overheating caused cracks in the weak spots and caused coolant to seap out between the block and steel cylinder sleeve(s), mimmicing a blown head gasket.
I have an 04, did a full rebuild last year(bad bearings), pressure tested block and coolant system sucessfully prior to disassembly. When attemping to start the rebuilt engine...coolant in 3 cylinders.
A small amount, but apparently after a completely new coolant system, that became the weak spot, yay.
I just got a good 4.0 short block this past saturday, and will transfer the new guts of my 4.6, plus it's crank and rods into the 4.0, making it a 4.6
Also, some earlier model D2's Did have a factory cdl.
No 03's did, although some 03's just need the cdl linkage to work, others do not have the shaft coming out of the case to attach the linkage to.
So could one just get an 03 range rover motor and transplant that in there for better longevity?
Old Nov 14, 2019 | 10:40 AM
  #24
Sixpack577's Avatar
From what I understand, yes, and from 1998 to 02 or 03, I forget the last year of the P38 4.6 in the RR.
That, or a 4.0 and swap in the 4.6 crank and rods, which is what I'm doing now.
I got a good 4.0 short block last saturday after a P38 4.6 block deal fell through.
Old Nov 14, 2019 | 10:46 AM
  #25
Dave03S's Avatar
Through 2002. 2003 RR started using the BMW engine which you would not want.
Old Nov 14, 2019 | 03:44 PM
  #26
Best4x4's Avatar
The 4.6L vs 4.0L HP wise = small really. 217HP vs 188/190HP. It’s the extra 50ft-lb’s of torque which helps. No LR with any variant of the Buick 215 V8 is a power house.
In the mountains staying out of 4th gear and not being weighed down will help, but it’s not gonna win any Pikes Peak races.
If you want HP & performance ditch the old Rover V8 for an LS 4.8/5.3L and get the kit from Trailhead 4x4. Keeps it fully operating with the OEM sensors/equipment. You can get an all aluminum 5.3L (not sure about the 4.8L).
Also if you have a 99-02 with the HP22 it would be a good time to slap in an HP24 to handle the extra HP with the swap.
Deespin
Jul 18, 2017 09:50 PM
MarkSF
Feb 1, 2014 01:10 PM
screenburn
Dec 30, 2012 08:02 PM
Dudemobile
Feb 18, 2008 11:07 PM
ferrelltodd
Jan 26, 2006 01:23 PM
