A/C & Heater doesn't blow air
Hello!
I recently purchased a 99 Discovery 2, the A/C & Heater won't blow air. However, when I'm in motion, I can feel cold air coming through, but when I stop the air also stops. Does this sound like a bad blower? I checked the relay, it works. All controls work, A/C compressor turns on. I live in Texas and its killing me to not have A/C. Any help/suggestions would be appreciated. -Melting in Dallas. |
It could be a bad blower motor, applying power straight to motor will answer that.
Most likely it's the cracked solder problem in the interior fuse block. My write up several years ago: https://landroverforums.com/forum/di...m-fixed-22524/ |
I have had 2 of the wiring plugs melt. You can access the blower motor under pass footwell. Pull the plug and the 3 or 4 bolts that keeps it together and you will see if itnis melted. Cut the plug off and Re-wire with butt connectors and you will be back in business.
