A/C & Heater doesn't blow air
Old Jul 20, 2019 | 02:44 PM
New2Discovery's Avatar
Default A/C & Heater doesn't blow air
Hello!
I recently purchased a 99 Discovery 2, the A/C & Heater won't blow air. However, when I'm in motion, I can feel cold air coming through, but when I stop the air also stops. Does this sound like a bad blower? I checked the relay, it works. All controls work, A/C compressor turns on. I live in Texas and its killing me to not have A/C. Any help/suggestions would be appreciated.
-Melting in Dallas.
Old Jul 20, 2019 | 05:13 PM
PalmettoDisco's Avatar
It could be a bad blower motor, applying power straight to motor will answer that.
Most likely it's the cracked solder problem in the interior fuse block.
My write up several years ago:
https://landroverforums.com/forum/di...m-fixed-22524/
Old Jul 20, 2019 | 06:45 PM
00 Disco II's Avatar
I have had 2 of the wiring plugs melt. You can access the blower motor under pass footwell. Pull the plug and the 3 or 4 bolts that keeps it together and you will see if itnis melted. Cut the plug off and Re-wire with butt connectors and you will be back in business.
me 2
Mar 1, 2016 07:33 AM
welder403
LR2
Dec 17, 2015 06:21 PM
olywa
Nov 28, 2015 04:47 PM
Antinius
Aug 5, 2010 04:53 PM
jdad49
Jun 8, 2010 09:00 PM
