C Pillar removal and installation
Old May 21, 2011 | 09:01 AM
harryashley's Avatar
7th Gear
Default C Pillar removal and installation
Hi,
Would apreciate if someone could tell me how to remove EXTERIOR C Pillar trim and re-install? It looks complicated to me!
Thanks
Old May 24, 2011 | 08:24 PM
lordmorpheus's Avatar
You have to remove the interior panel covering the C pillar. The exterior C pillar trim is retained with three nuts per piece that have to be removed from the inside. Once you get the interior panel off, it is a cakewalk.
Old May 25, 2011 | 07:55 PM
7th Gear
Thanks very much, it was fairly simple!
Regards
Old May 25, 2011 | 10:04 PM
Glad I could be of assistance!
Old Jul 6, 2011 | 01:04 PM
ksiptroth's Avatar
Default C-Pillar install
Hi, I need to replace the same thing. Does anyone know what it takes to remove the interior pillar to get to the nuts? Thanks
Kyle
Old Jul 6, 2011 | 01:37 PM
At the bottom of the interior panel, there are some dime-sized retainers. These are actuallt screws. The head of the retainer cap opens (and probably falls off completely because the small piece of plastic holding the cap to the retainer breaks). There are also some "Christmas tree" style retainers at the top of the trim that just pull straight out. There is also a smaller "christmas tree" style retainer at the lower front of the panel (right near the 2nd row seat). Once all of the retainers are removed, the panel just prys loose from some clips behind it
Old Apr 22, 2017 | 03:42 PM
hankeester's Avatar
anybody know what size nut is on that threaded t screw that holds on the C trim pillar? I've put everything from metric and standard starting with 3/16" but can't seem to find the right socket and you can't really get to it since it's inside the body panel.
Old Apr 22, 2017 | 05:48 PM
JEFIII's Avatar
I just did this a couple of weeks ago. It is a 6pt. 9/32 socket. Get a couple of them. I dropped one inside the panel and it disappeared. Good luck. JEFIII
Old Apr 23, 2017 | 08:12 AM
hankeester's Avatar
That explains it, the one socket I didn't have! thanks for the response.
rcg'sdisco
Feb 2, 2014 12:23 PM
Twins Disco
Dec 16, 2013 01:50 PM
ralphobell
Apr 1, 2013 11:09 AM
BSundownerC23
Feb 28, 2010 11:24 PM
jlgolson
Jan 14, 2010 07:56 PM
