A/C problems
Old Jun 22, 2010 | 03:22 PM
1stshift's Avatar
7th Gear
Default A/C problems
When I turn the A/C on all I get is warm air. I opend the hood and noticed that the clutch was not engaging. I bought a recharge system and when I hooked it up it said that the A/C system had a pressure of almost 65lbs and was in the yellow of the scale as over pressured. I drove it around for quite some time and the A/C never would engage. I do not know if the A/C ever worked as I live in the Pacific Northwest and have never turned it on before. Any help would be great. Thnak you.
Old Jun 22, 2010 | 03:49 PM
hilltoppersx's Avatar
what do you drive
Old Jun 22, 2010 | 04:00 PM
1stshift's Avatar
7th Gear
2000 disco II
Old Jun 22, 2010 | 06:13 PM
1stshift's Avatar
7th Gear
I got it to work. I moved the relay up and down a couple times and the connection on the a/c pump a couple times. There must have been somethnig keeping it from making full contact.
Old Jun 22, 2010 | 07:47 PM
Make sure you use the a/c once a month even in the winter time (just turn the temp to hot), this keeps the compressor seals lubed so they dont dry out.
Old Jun 22, 2010 | 08:29 PM
okdiscoguy's Avatar
I use my a/c year round. I can't do without it. Get my feet dragging snow in with the heater, it fogs up all the windows. I don't see how you do without it..
Old Jun 24, 2010 | 11:32 PM
doomed's Avatar
My AC blows hot on the passenger side, are there two connections? Did your AC blow hot on drivers and passengers side?
Old Jun 25, 2010 | 11:10 AM
LuvToDisco's Avatar
Bump! I noticed that mine does this too. Anyone got an answer?
Old Jun 26, 2010 | 10:19 AM
1stshift's Avatar
7th Gear
Mine would blow nothing but warm air out of all the vents. When I looked at the pump the center was not turning/engaging. I moved the relay in and out a couple times making sure it was seated real good the last time I pushed it back in and I disconected and reconected the plug at the pump a couple times. This worked for getting the pump to engage. I was then able to get a proper pressure reading and I recharged the system. I now have ICE cold air from all vents and it seems to be working great.
Frank4
Mar 21, 2014 05:21 AM
