Can I drive D2 without suspension lvling fluid
You will have to excuse me but I know very little about this car. Here it goes, going to the gas station the other day, it made a sudden fluid leak. The fluid appears to be the fluid that adjusts the suspension (is that ACE or something else). The reservoir (cap with the car with two arrows on either side) is empty. My father (the owner) does not care about any optional feature that is now failing. I am desperately needing to use this vehicle to get to school next week.
Is it safe to drive with this suspension fluid gone? I imagine the pump for this feature is belt driven, could it seize and cause problems? Thank you for your time to answer this.
Jon
Jon
In an attempt to find an answer to my question, I came across this link: http://www.landroverclub.net/Club/HTML/ace.htm at one point it says
"If you break the lines while driving you will not notice anything abnormal. So LR incorporated a red flashing light and a buzzer.... If the light goes red and the buzzer goes on, you lost so much fluid that the pump can be damaged. Theorhetically the system closes the lines before this and switchs the pump to bypass. In this case you will notice much more body roll but you can still drive."
I appreciate your response Spike, I am certainly not trying to challenge anyone, I am simply trying to find the truth. If this link on ACE is factually inaccurate I hope someone will point that out. Also the system gushes ACE fluid, so putting some PS fluid in wont help much.
hriant88
11-09-2014 07:05 PM
TripleThreat
04-12-2011 08:58 AM
