Can the transfer case solenoid be repaired or just tossed?
Most of us just remove them, but if you feel you need it, replace it. I haven't read of anyone fixing a broke one. I don't know why they fail, other than the fact they are an electrical device in a Rover that's getting old.
It’s a solenoid & they either burn up, or get stuck. I personally have removed the unit from my 02 Kalahari, (was stuck in 4Hi when I bought it), so I made a blank plate for it, and sealed it up with some black RTV. Then I installed an 04 CDL Linkage and just simply plugged it in (03-04 interlock is not on the TC anymore. It’s mounted on the 4Hi/N/4Lo linkage instead. So if you can get a hold of an 03-04 unit (03 if you don’t have a CDL & 04 if you do) it’s a PNP upgrade vs the older setup & much easier to work on in the future.
I either removed the solenoid out of the housing or I just hack sawed the rod off the solenoid and bolted the housing back on? I don't remember the particulars. I did the job from the top because I was also installing my 04' linkage, tight quarters but doable. The solenoids job is to prevent the vehicle from accidently being placed in neutral by a child or mommy and rolling down a hill, some call it a soccer mom safety device.
Lisa Bunch (05-01-2019)
I have access to small metal plates/shims from work. I took a 1/8 thick shim, and clamped it to the original interlock solenoid cover. Drilled the 4 holes, and then I used a grinder to make it exactly the same size. Took me maybe 20min to make. I was able to remove the old unit & install the plate with the TC installed and from underneath. I just removed the Ebrake drum assembly for the most clearance.
Once the driveshaft is out of the way you just use a manual impact driver to remove the #3 phillips head bolt that keeps the drum in place, then the main drum cover will slide off. The backplate is held onto the TC with 4 15mm bolts. After that you can move the assembly out of the way or go one step further and remove the clip on the ebrake handle & sit the assembly out of the way totally. I’ve done it either way.
