Can't find kickdown cable adjustment in RAVE
Title pretty much sums it up. I got a '00 Disco II. It up shifts late and downshifts only if I give a hefty pulse on the gas pedal. The latter usually happens after slowing down or coming to a stop.
anyways after some research and a trans fluid change (the fluid was still semi red and clear) I'm hoping the culprit is an out of adjustment kickdown cable.
can someone please tell me where in the RAVE manual the adjustment directions are? I've read through the engine/throttle/and auto gearbox sections and couldn't find anything. Maybe I don't have an updated version so if someone could post a link to the final version please.
thank you
thank you
But nope not in sport mode. Besides it wouldn't explain the no gear when I come to a stop. If I slow down to a stop at a stop sign from 35+ mph, when I hit the throttle to proceed I have no gear. I have to rev up the engine to 1500+ real quick then it drops down into gear and I can accelerate again.
Any input on my situation I mention in the above reply? I need some milk/help.
How much fluid is it missing with it being filled without running? I read it's 5qts for ATF drain and fill. If I recall correctly it took about 5qts.
Been there. Done that.
