Can't get low-speed temps down.
Old 10-10-2019, 09:32 PM
cvhyatt's Avatar
Originally Posted by Jason_B
I think the 2004 has an integrated fan and clutch so I don't think the HD clutch is plug and play but I am also interested in this upgrade so please let me know how it goes.
Replacing the whole fan assembly tomorrow. Will let you know how it goes!
  #22
Old 10-10-2019, 09:33 PM
cvhyatt's Avatar
Originally Posted by shanechevelle
Try parking it on a hill, get that front end up.
I dont do anything but park on a hill, let it run, open that bleeder. I also squeeze my hoses.
New parts always help.
Green FRESH coolant. Coolant does go bad.
Engine has been rebuilt with new radiator, stat, water pump and new coolant. Replacing the fan tomorrow then the stat if that doesn't work.
  #23
Old 10-11-2019, 05:27 PM
cvhyatt's Avatar
Fan replaced. No change. Waiting on new low temp sensor.
Removing the fan
Old fan. I hope it is bad.
New fan
  #24
Old 10-11-2019, 07:26 PM
The_OGCJR's Avatar
Your temps are fine. Those are my temps and I run an in-line setup.
some of our trucks run hotter than others. 220 is on the high end but I wouldn’t “shut it down” unless it went over that.
I live in Texas
cvhyatt (10-11-2019)
  #25
Old 10-11-2019, 07:43 PM
Llamasayswhat's Avatar
220 is way higher than you should be while cruising around. You have a badly performing radiator, weak fan, or the normal t-stat and not low temp.
  #26
Old 10-11-2019, 10:29 PM
cvhyatt's Avatar
Radiator, fan and water pump all replaced. New genuine 180 stat on its way!
  #27
Old 10-12-2019, 06:56 AM
Extinct's Avatar
Received 1,463 Likes on 1,039 Posts
Agreed, I have lived in the south the entire time I have owned Discos. Hottest days it should run no more than 195 going down the road, it should idle at 204 initially but will creep up if you idle for long periods in a car line.
  #28
Old 10-12-2019, 09:15 AM
The_OGCJR's Avatar
I should be more clear.UP TO 220 at idle or in bumper to bumper traffic would be normal.
when driving, 200 is high.
  #29
Old 10-12-2019, 09:22 AM
cvhyatt's Avatar
221 at idle
215 to 221 below 1700 rpms
197 to 212 At speeds around 60-70
  #30
Old 10-12-2019, 10:49 AM
Best4x4's Avatar
Received 2,272 Likes on 1,676 Posts
Any 03-04 D2 with the one piece fan/clutch can run a 99-02 setup. Get the fan clutch and slap it onto an OEM 99-02 fan blade or Dorman 620-112 fan blade. The one piece unit on 03-04’s is extremely over priced IMHO.
Quick Reply: Can't get low-speed temps down.
