Castrol and zink contents
I reached out to Castrol to see how much zink is in the different oils they have
here’s the response
Thank you for contacting Castrol North America.
Castrol does not publish any formulations or changes in formulations. Our additive systems and base oils are proprietary and chosen for performance and suitability first. Castrol uses only the highest quality materials, including synthetic base oils.
Thank you again for contacting Castrol. We value your patronage!
Castrol Consumer Relations
here’s the response
you will find nearly no zinc in any modern oils. Even ones that advertise with "higher levels" are miniscule compared to what you used to to get. Modern engines don't rely on zinc anymore as an additive, and it ruins catalytic converters.
If you're concerned about zinc content, get an actual additive and pour it in
TRIARII
05-23-2015 04:31 PM
