Catastrophic Coolant Loss
Hey all - 2000 Disco II w/194k.
I’ve been nursing a minor rear-engine coolant leak for quite some time now. I wasn’t sure of the leak’s origin…..it would drip down around the bell housing area (valley pan maybe?). In any event, this is sort of a “beater vehicle” and a topping off of the reservoir once a week or so would suffice and I never experience any overheating, etc.
Today, whatever it was (assuming it’s the same area) finally let go once and for all. Upon parking (luckily) something let go and the coolant emptied out in a matter of minutes. It was difficult to zero in on a source because A) it was being diverted by various components and B) it was burning/smoking as it poured onto the y-pipe/cats.
I know it’s a tough diagnosis to make with only this info but, anyone have any thoughts on possible culprits back there?
Thanks for the quick reply.
The only thing that has me questioning the valley or head gaskets is how quickly this thing emptied out. It was, literally, like someone pulled a major hose off. I'd say that 95% of the coolant capacity was on the ground within a minute……and this was at full operating temp after about 2 hours of driving.
I see no signs of spray anywhere around the top-rear of the motor (dist/coils, etc.). Aside from the heater hoses that go into the firewall, are there any other major cooling lines tucked in directly behind the motor?
The only coolant lines that run back there are heater hoses and engine gaskets.
The throttle body heater plate is up top on the drivers side but that always leaks down that side of the engine and not out the back usually.
Rinse the engine off with clean water, then fill it with colored water and see what you find.
Good (not really) call 04Blu
Although I can't see the plug itself, I can see a pinhole stream of water shooting out from the rear of the block.....and there doesn't appear to be any coolant lines/hoses in close proximity. I can't reach it, from any angle, with my hand and I'm not sure that intake removal is going to help that.
Unless a stop leak product could fix it (which I don't think I'd trust even if it did), this is going to be a difficult decision. If this will require head removal or partial engine lift-out, I may be done with turning wrenches on this old girl.
Anyone have a couple of pics of the rear of an out-of-truck motor....so I can try to get a feel for the exact position of these plugs?
Thanks again for the quick responses and, unfortunately, accurate suggestions.
