Center console white smoke
I can't be any more frustrated with my disco 04. I definitely hate it.
After spending a small fortune replacing the head gasket the starter motor begin to act up. According to the mechanic the antifreeze from the leak of the head gaskets corroded the starter motor, so some times when I go to stat it up I get a like a click, click like the battery is drained. So today when I went to pick up my kid from day care the car did not start, again with the click, click, I notice quite a bit white smoke coming out from the central console. Definitely something is burnt but I don't know what, windows work, heated seats don't know due to being summer in STL and very hot, electric seats work. Please help, what can be burnt and is it worth it to look what can it be. |
Plenty of things with connections, grounds, wiring headers, in the console. You'll need to open it up. The RAVE electrical circuits manauals and electrical library (pictures) are a great help. Worth it, yes. Possibility of vehicle fire and loss of vehicle, plus home if it is parked in garage.
(Post 409043)
thank you for the help. The future of my disco is not looking good.
If you have anything installed on the truck that did not come from the factory, like a different radio, GPS, lights, etc.; these are places where people cut corners on wiring and fuses.
OH horse poo poo.
You have a bad ground. The ground circuit is going thru your hand brake cable to ground and smoking the cable. You need to get the braided ground wire from the driver's head to the firewall installed. Who ever did the heads figured - oh I will leave that wire off. Who needs it anyway. Wrong. The battery grounds to the chassis. So, does the engine. If the engine and transmission are not perfectly grounded, then the current when you start the engine will find creative ways to ground - like white smoke from the burning ebrake cable. Which can burn your hand too by the way. |
Your heated seats are NOT going to work in the summer. Too hot and the hi limit temp is reached - so the seats remain off.
Wait until all the oranges freeze in the winter then try the seats. |
Originally Posted by jfall
(Post 409068)
OH horse poo poo.
You have a bad ground. The ground circuit is going thru your hand brake cable to ground and smoking the cable. You need to get the braided ground wire from the driver's head to the firewall installed. Who ever did the heads figured - oh I will leave that wire off. Who needs it anyway. Wrong. The battery grounds to the chassis. So, does the engine. If the engine and transmission are not perfectly grounded, then the current when you start the engine will find creative ways to ground - like white smoke from the burning ebrake cable. Which can burn your hand too by the way. He's right. Search for my thread titled: Disco Inferno. |
I would call thew mechanic and have it towed back to him, then put a 4 Sale sign on it.
(Post 409068)
OH horse poo poo.
You have a bad ground. The ground circuit is going thru your hand brake cable to ground and smoking the cable. You need to get the braided ground wire from the driver's head to the firewall installed. Who ever did the heads figured - oh I will leave that wire off. Who needs it anyway. Wrong. The battery grounds to the chassis. So, does the engine. If the engine and transmission are not perfectly grounded, then the current when you start the engine will find creative ways to ground - like white smoke from the burning ebrake cable. Which can burn your hand too by the way. I opened the console and the ebrake cable was burnt. Two questions: 1_ How difficult and or expensive is to replace the wire from the driver's head to the firewall. 2_ How difficult and or Expensive is to change the ebrake wire. |
| All times are GMT -5. The time now is 07:25 AM. |
