center diff NOT locking
no there is no lurching feeling, but when i lock it it seems not to have as much acceleration, is that normal? i climbed under it and had someone lock it and unlock it, it seems to be moving the nipple about 1/2 inch maybe a little under.. how far is it supposed to travel? it doesnt seem to be bent, besides the bend that looks to be a 90 from the factory.
its at about the 6 o'clock position now, how far should i try moving it? also should i have the handle in the locked or unlocked position when i do it? also what do i need to remove the linkage or will it just pop off?
I was under the impression that the cdl will only "lock" the front and rear end, and turn off the ect. The axles are still open diff's and allfour wheels wont spin under a load unless you have front and rear lockers. Maybe this is a difference between the DI and DII?
ORIGINAL: tailchaser0527
I was under the impression that the cdl will only "lock" the front and rear end, and turn off the ect. The axles are still open diff's and all four wheels wont spin under a load unless you have front and rear lockers. Maybe this is a difference between the DI and DII?
Also, with out CDL you can not run lockers.
I recently hooked up a "ghetto lever" on my '99. The nipple stud is 8mm and I believe the nut size was 13 or 14mm. While on the subject of CDL I would like to share a story about something that recently happened to me. We got a bit of snow the other day. I've got a short,steep hill on my farm that's about 6' tall and the angle is about 75 degrees.(fairly steep)
It's grassy and I have climbed it several times with my disco as well as my Dakota 4x4 and S10 Blazer. The other day there was snow on it. I went to climb it with the disco. ETC kicked in but I didn't make it over the top. I backed up, got out, and engaged my Ghetto lever for CDL.
I still didn't make it over the top. Here's what's interesting though.....when I had gone as far as I could the ETC was swapping power side to side on both the front and rear axles as traction was lost, causing the vehicle to slide left and right in both the front and the back. It was comparable to a snake trying to slither up the hill. The truck was staying in one spot with traverse motion on both ends. I then went a got in my Dakota and climbed the hillwith no problem. This ticked me off. Of course the Dakota is a lighter vehicle and has more aggressive tires. The point of this story isin facttires. My Disco had Yokohama Geolander tires on it when I bought it, and they are practically brand new and they are more of a street tire. I can't justify replacing them right now but the crux of the buscuit here is.....CDL......ETC....LIFT....LOCKERS...whatever. .......if you don't have decent tires you still may not go anywhere.
Decent tires should anyways be your first investment. Yeah, it sucks when you buyatruck with brand new street tires, unless you don't see snow or go off road.
