CENTER DIFF QUESTION
Old Nov 25, 2008 | 08:42 PM
73S3IP's Avatar
Default CENTER DIFF QUESTION
I know that the traction control system on the DII works with the ABS to control brake force at each corner for torque distribution from wheel to wheel in an axle under slippery conditions (when it works). However, what controls the torque split between the two axles with that open center diff for those of us with, say, an '02 that can't lock it?
Old Nov 25, 2008 | 08:48 PM
Urban Panzer's Avatar
Default RE: CENTER DIFF QUESTION
The TC system looks across the axles as well as front to rear to get its "average". So the TC system will control the torque split front to rear.
Old Nov 25, 2008 | 11:14 PM
73S3IP's Avatar
I will be honest in that I dislike this electronic business with respect to my four-wheel drive system. The failures, temporary fixes, and potential for failure (of this ABS system) on these leave me feeling uneasy. I prefer hard parts mechanically connected to other hard parts. That being said, I am looking into LSDs front and rear - leaning toward Truetracs. That leaves me with this center diff that, when the three amigos come knocking, leaves me with an open diff in the middle. What are my options to fix this on my '02? I have read about homemade linkages and shifter kits/linkages for those with late '99s,'00s and '01s to reconnect and operate their locking centers, but what abutthose of us rockin' the '02s and '03s?
Old Nov 26, 2008 | 03:33 AM
Disco2Guy's Avatar
The '02-'03 trucks are s.o.l. unless you do a t-case swap, or have the cdl bits retrofitted into your current case. I'd do that before adding any sort of locker.
Old Nov 26, 2008 | 04:17 AM
I agree with D2Guy, you would be better investing the money in retrofitting your transfer case with a CDL first. Will actually work out cheaper than buying lockers for the front and rear to.
2 options, eithrt fit a complete transfer case from a scrap / wrecked vehicle, or buy the front output casting and CDL components and fit them to your case. All depends on what sort of mileage / condition your case is in etc.
Old Nov 26, 2008 | 07:27 AM
jycsalas's Avatar
Where can we get this retrofitting kit?
Old Nov 26, 2008 | 08:28 AM
From here in the UK, it wont be cheap.........but how bad do you want a CDL ??
http://www.ashcroft-transmissions.co.uk/part_17.html
Old Nov 26, 2008 | 08:48 AM
There is another option, buy a used damaged LT 230 t/case, remove the diif portion, clean and install it on your old t/case, then all you need is the linkage.
Old Nov 26, 2008 | 08:54 AM
jycsalas's Avatar
$350 USD plus shipping!! I think thats cheaper than buying another TC.... and one could just make a custom shifter handle. Honestly, my traction Control works great for the novice trails I've found so far on this island. Maybe one day when I move back to the U.S. mainland I'll see a need for it.
Old Nov 26, 2008 | 10:34 AM
73S3IP's Avatar
I definitelywant the locking center diff on this rig. I am just working my way through the options to find the best one. Was the LT 235 t-case used in the DI's? I may know of a DI that is just sitting. I don't think it has been driven for a good while and thought about checking to see if I could either get parts off of it or just get it for anyting I could use. Any thoughts on this?
Also, is swapping those parts over to my t-case something a shadetree mechanic could accomplish, or does it require getting at the guts of the box -and is, therefore, best left for a pro?
