Charging question
Richard Gallant (08-17-2023)
Hey Richard,
I hope the weekend 4 day run went well. I switched to this 150-amp alternator earlier in the year. I encountered similar voltage readings from my Ultraguage with the hot 90F-plus ambient temps on our run last month.
https://www.ebay.ca/itm/300369751057
@acg trip was gerast only one "bad" road, I had to leave monday night. Thanks to you and @Discorama I figured it might be heat related.
Thanks for the info, I appreciate it. I am glad I found your post. I was searching for the Juicy Vegas no deposit bonus codes online and I found https://casinosanalyzer.com/casino-b...juicyvegas.com website where I found them and also found those sites in which I can play online real money games. Now, I easily can make money while sitting at home.
@Extinct yea that was my problem trying to figure out the control system, to determine if I had an issue. Seems to be ok, as long as it stays above 13 V
It is worth going through this process if you have a problem :
To check if you have a bad connection either on the positive from the battery or the ground.
- Next follow the positive to the fuse box and verify you still have your 13.x between there and the body of the car.
- If not check between positive at fuse box and neg term on battery.
- If that's good you know the positive wire either has a sketchy connection or one of the crimped on terminals is loose or something.
So I have had sometime to do some detailed testing :
Alternator positive to alternator body 14.0 to 14.2
Alternator Positive to battery negative 13.8 (battery is pretty much charged)
Alternator to engine side of the negative battery cable 13.8
Alternator to battery cable mid point ground 13.4 or less it mirrors my voltage on Torque never below 12.9/8- this appears to be the an issue it should be 13.8
Engine Fuse box main positives to battery negative 13.4 mirroring the battery mid point ground
My assumption is there is a problem with Negative battery cable,at this point.
But as I am often mistaken any other suggestions ?
