chevy diesel conversion
yeah I know we talk about swapping in a diesel all the time, but has anybody done the chevy diesel swap? There's a guy on my local LR forum that is putting one in a D1. He's using the 6.2L but I would of gone with the 6.5L. He picked it up from a army base (engine is used in humvees) I remember seeing the adapter kit for this conversion a while back. Its $1k for the transmission kit and $150 for the engine mounts. He claims the engine doesn't weigh as much as other diesels of similar size.
mike, I don't see any reviews out of the ordinary for failure rate. My experience has been these engines are dependable but the 6.2 is under powered. I'm not very familiar with the 6.5. I wasn't considering putting one in my DII, just think it might make a good engine for a future D1 project.
spike, the 6.6L version of this engine has aluminum heads, but yeah the 6.2 and 6.5 are cast iron. It looks like they weigh between 900-1100lbs. It will be interesting to see what kind of suspension this guy uses up front.
on
So I am confused, are you wanting to install one in your D2 or a D1? Remember, can't be done with a D2 because of the computers.
I have the 6.2 in my scout that I swaped in. I realy like the way it runs and drives for the most part. The Turbo 6.5 would be more powerfull but that is a very wide version because of the exhaust manifolds and Turbo hangin off the side of it. Because of the 6.2 being NA I would say that it would be the more dependable engine even thought they are almost the same motor minus the turbo. Having the 6.2 or 6.5 in a realitivly light Discovery compaired to a Hummer would prolly net you around 20mpg. Last time I checked I was getting a touch above that in my scout with 33" tires and a 3.54 gear.
